Discussion topic: Broadband not working
This message was authored by: Nichola2603
There are 2 orange lights on router
Re: Broadband not working
@Nichola2603
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
