Discussion topic: Broadband not working
This message was authored by: Sarahfairhurst
My router is just flashing green
Re: Broadband not working
@Sarahfairhurst
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
