Discussion topic: Broadband not working
This message was authored by: User34
It's saying there is a broadband issue which is why my wifi isn't working. Run all the tests and it's saying everything is fine. What's going on?
Re: Broadband not working
@User34
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
This message was authored by: Drummer84
Same here in Fareham. Outage map on down detector showing issues at sky. But router all green lights yet I'm getting same as you!
Avatar for User34
Level 0 icon
I'm in West Sussex, I'm working from home and it's driving me crazy. Run all the tests on the app and the links given on this thread. Just says 'everything's ok' but clearly it's not! 🤣
Avatar for User34
Level 0 icon
Thank you for your reply, I've tried the links you've given and the tests in the app and it's not working. Hopefully it's sorted soon.
Same here, working from home. At least reassuring we are all in same boat and not a problem in house with our services, cables, router issue etc. Hopefully back on soon.
This message was authored by: User772
Same location here! Since joining Sky the broadband has been terrible even after 3 visits to 'fix' it. Not good enough as I'm also working from home.
Avatar for User34
Level 0 icon
Maybe it's a problem in our area that hasn't been picked up yet? I've had a few problems but nothing I've had to call out for yet as it has eventually sorted itself out on the same day. But I do find as soon as we have any kind of rain, even if it's very light rain, the connection is terrible!
Avatar for User34
Level 0 icon
It's back on and working! 🥳
To be honest, we've been with sky here in Fareham for 2.5 years and never had an issue like this. On downdetector it seems national issue as showing hotspots in every major city.
