Discussion topic: Broadband not working
Message posted on 21 Oct 2025 02:46 PM
Message posted on 21 Oct 2025 03:10 PM
Re: Broadband not working
@Juliebillings
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
