Discussion topic: Broadband not working
Message posted on 04 Jul 2025 01:53 AM
There is an orange light on my hub and when I test the hub it states there are no issues, but clearly there is I am not happy as an individual with a disability I require access to my internet.
Message posted on 04 Jul 2025 03:47 AM
Re: Broadband not working
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 0700, and you haven’t done it yet, use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 04 Jul 2025 08:22 AM
@Shortie986543 As @Daniel0210 has pointed out, and if that is not the case and you are finding that you have continual loss off the Internet and displayed by the Orange Internet light, then DO call sky and have them take a look see if they can spot it with the diagnostics that they have available to them!
Message posted on 04 Jul 2025 08:25 AM
Message posted on 04 Jul 2025 09:41 AM
@Simonecapewell For you the link below is about the hub and it's light's!
