Discussion topic: Broadband not working
Message posted on 29 Jun 2025 07:57 PM
Our broadband is not working. I have run diagnostic checks through the MySky app and it says everything is fine but we still have no Internet. I have tried turning the router off and on again three times now and nothing has changed. I need Internet right now so please can someone help me ASAP thank you.
Message posted on 29 Jun 2025 07:59 PM
Re: Broadband not working
@ChrisJ5
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 01 Jul 2025 06:27 PM
I am having exactly same issue
Wen run checks says all is ok but it obviously isn't
Message posted on 01 Jul 2025 06:29 PM
The above advise applies to you too.
Message posted on 01 Jul 2025 08:50 PM
Thank you. Yes i did all that and all is saying is ok so will need to contact Sky
