Discussion topic: Broadband not working
This message was authored by: Markepsom
Broadband went down about 10 minutes ago
Re: Broadband not working
@Markepsom
If your broadband still isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: Jodiem
Also in Epsom and Broadband down. Diagnostic checks saying all is fine but no broadband or WiFi.
This message was authored by: StoneleighSky
In Epsom and our broadband down as well for last 45 mins but all sky checkers saying service is fine - which it's not. Am hardwired in from hub so can see no signal coming through.
@StoneleighSky @Markepsom @Jodiem Until sky become aware of a particular area wide fault then the software cannot and does not get that fact out there!
