Discussion topic: Broadband not working
This message was authored by: Shar+Tyndale
My broadband isn't working
Re: Broadband not working
@Shar+Tyndale
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
