Discussion topic: Broadband not working
Message posted on 16 May 2025 06:42 AM
My broadband is not working and I really need this fixed by today, as I have a court hearing at 2pm that I have to attend via video call and my mobile phone does not working properly without being connected to my wifi
Message posted on 16 May 2025 06:58 AM
Re: Broadband not working
@AshleyShania I would be looking at alternativea now as a fault reported this morning is unlikely to be assigned an engineer for 2 days. Always hope for the best but plan for the worst. Best of luck.
Message posted on 16 May 2025 06:59 AM
@AshleyShania
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Regarding the court case, you may have to consider alternative options such as personal attendance.
