Discussion topic: Broadband not working
Message posted on 19 Mar 2025 10:17 AM
Message posted on 19 Mar 2025 10:18 AM
Re: Broadband not working
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 19 Mar 2025 10:19 AM
Message posted on 19 Mar 2025 10:20 AM
@Church20
