Discussion topic: Broadband not working
This message was authored by: Tracy85
Internet not working, no light on hub, have tried switching off and on but still not working
Re: Broadband not working
@Tracy85
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
Avatar for Tracy85
Broadband is now working thanks
