Discussion topic: Broadband not working
Message posted on 16 Jan 2025 12:32 AM
Message posted on 15 Jan 2025 10:35 PM
Broadband down again
Hi, broadband seems to be down again in Keighley. Went down this morning and came back about 10ish. I now have red light on max hub again after it was working most of the day. No way to report it online. Anyone else with same issue as system claims nothing down external
Message posted on 16 Jan 2025 12:44 AM
Re: Broadband not working
So has ours
Message posted on 16 Jan 2025 12:47 AM
This is the same problem I'm having almost every day
Message posted on 16 Jan 2025 01:07 AM
Internet down but check says all OK
Internet and voice calls has been down since around 23:30 on 15/01/24. I have tested the connection with a backup router (different cables) and there is no change.
However, the Servicechecker states that everything is OK. This is not the case. The Servicechecker says my hub is reachable at all times, even when it is disconnected and powered off.
Message posted on 16 Jan 2025 01:21 AM
Message posted on 16 Jan 2025 01:27 AM
I am, down for me.
Message posted on 16 Jan 2025 01:35 AM
I am in the Wakefield area and my wifi is down!
Message posted on 16 Jan 2025 01:53 AM
At least now we now know that there isn't an issue with our kit and that the problem is with the connection (in the Wakefield area). The sky.com/servicestatus test is a bit of a joke at the moment. It flags everything as OK, even when my hub is powered off.
Message posted on 16 Jan 2025 01:57 AM
I'm in wakefield, finally managed to get it to recognise a fault and an engineer is booked, its not in my property, its somewhere between them and me, I'm presuming it will be the same fault that's affecting us all.
Message posted on 16 Jan 2025 02:17 AM
Back up for me now (Wakefield).
I'm in London. Mine has gone down too
Message posted on 16 Jan 2025 02:48 AM
It's back up for me now
Message posted on 16 Jan 2025 06:33 AM - last edited: 16 Jan 2025 06:36 AM
Re: Internet down but check says all OK
@JD127
edit- merged with your other posts.
