2
This discussion topic has been answered Discussion topic: Broadband not connecting
This message was authored by: KAC1
I have reset my router so many times and it's not connecting to the internet
Re: Broadband not connecting
@KAC1
@KAC1
If there's an external fault then restarts don't achieve anything.
