24 Jul 2023 01:11 AM
I have broadband with Sky which I've had for a few months now, however, the broadband has proven to be quite slow rarely reaching the speeds that it should along with occasionally cutting out entirely for a few minutes and forcing me to manually reconnect to it on my PC, My first thought was to use the service checker to test the speed however when I go to the service checker it strangely says that my broadband isn't with Sky which isn't true since I'm connected to it even at the moment that I'm writing this, This makes it impossible to seek support through the service checker since it won't even recognise that I'm using Sky broadband at all and won't allow me to test the speed due to it.
24 Jul 2023 01:40 AM
Unfortunately you have joined at the worst possible time since the was hacked a few months back the broadband has been useless thankfully I have only a month left and I'm off.
with the money they make they should of been able to address the issue by now
24 Jul 2023 07:35 AM
Posted by a Superuser, not a Sky employee. Find out more@stephanie47 this normally happens because the wrong Sky id was used to log in you have to use the correct Sky id which is linked to your broadband account. If you are confused give Sky a call but they will be busy this morning after the weekend's storms.
If you would like the forum to help,with your spedd question please post your connection stats see Find your Sky Broadband router statistics
@Danny8sky no idea what "hacking" incident you refer to but there is no known overall issue with Sky's network speed I have experienced or seen reliably reported in the forum caused by a hack. Some users do have speed issues which is inevitable given the technology and number of subscribers but they are not related to a "hack".Sky like BT Retail, Talk Talk etc use the Openreach network switching ISPs to another Openreach ISP means any line problem moves with you.
31 Jul 2023 12:29 AM
I did check that but I am certain that the correct Sky ID was used to log in, Oddly enough I can access the very contract for Sky Broadband along with the specific broad package I have purchased yet it still says that my broadband isn't with Sky when I try and use the service checker.
31 Jul 2023 06:56 AM
Posted by a Superuser, not a Sky employee. Find out more@stephanie47 have you called Sky to discuss this issue if so what discthey say?
