Discussion topic: Broadband lagging
Message posted on 26 Aug 2026 05:04 PM
Broadband lagging
Broadband is often slow and is lagging in apps. It should be running much faster. Also doesn't seem to cover the whole house, can we have extenders please?
Message posted on 26 Aug 2026 06:02 PM
Re: Broadband lagging
We're only other customers here I'm afraid, you'll need to phone or chat with Sky directly. Either 150 on a Sky broadband landline or Sky mobile or have a look at https://www.sky.com/help/articles/contacting-sky
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
