Discussion topic: Broadband keeps dropping out
Message posted on 04 Jul 2026 06:03 PM
I have a Sky Q hub, but don't have multi rooms.
My broadband keeps dropping out every 10 to 20 mins, this has been going on since mid afternoon yesterday.
Every time I check the hub there is either no middle LED or a middle orange flashing LED.
I have re set the hub a number of times but the problem persists, the sky TV is unaffected.
Can you please give any advice
Message posted on 04 Jul 2026 06:08 PM
Re: Broadband keeps dropping out
On a side note Sky have been replacing Sky Q hubs (for free) for over 12 months as they no longer receive security updates.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
