Discussion topic: Broadband keeps dropping out
This message was authored by: Ni8
Message posted on 22 May 2026 02:23 PM
Brawn and is slow and keeps dropping out. Keep getting a warning on my PC
Find out more
Message posted on 22 May 2026 04:41 PM
Re: Broadband keeps dropping out
Do you have a poor signal in certain rooms as this is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
