Discussion topic: Broadband keeps dropping out
This message was authored by: Chrissyhoughy
Our broadband keeps dropping out and I can't find we're to report it. It's that bad I would really like to leave sky
Re: Broadband keeps dropping out
@Chrissyhoughy
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Chrissyhoughy Both those options can be done by calling sky, just dial 150 from your landline phone if it is working, or also 150 from a sky Mobile, both are free calls to sky!
