Discussion topic: Broadband keeps dropping off
This message was authored by: Migsy69
My broadband keeps dropping off.  I switch everything off and back in but it doesn't help anything.
Re: Broadband keeps dropping off
@Migsy69
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
