Discussion topic: Broadband keeps dropping off
This message was authored by: Michaelbird
Sky broadband keeps dropping off
Re: Broadband keeps dropping off
@Michaelbird
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
