Discussion topic: Broadband keeps disconnecting
This message was authored by: Tony267
The broadband or Wi-Fi keeps disconnecting from my iPad I've done a check and it's saying everything is okay
Re: Broadband keeps disconnecting
@Tony267 if other devices stay connected tge issue is low wifi signal where the iPad loses connection. However if all devices are affected check the lights on the hub see https://www.sky.com/help/articles/hub-lights-explained-start
