Discussion topic: Broadband keeps cutting out.
Message posted on 24 Dec 2025 06:12 PM
Orange light keeps on appearing on router, then flashing., followed by going blank. Consequently, my broadband keeps on being disconnected. This has been happening for over two hours..
Message posted on 24 Dec 2025 06:17 PM
Re: Broadband keeps cutting out.
See further down about the hub lights…
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
