09 Oct 2023 12:39 PM
The internet light keeps going off and then flashing Amber before going green but doesn't stay green very long. Power and WiFi lights stay green
09 Oct 2023 01:11 PM
Posted by a Superuser, not a Sky employee. Find out more@LeeShroff sounds like you have a line fault which needs sorting. Run the connection test in the My Sky app which works over a mobile connection as thst will tell you if there is a known problem.of which there are loads north of the border after thecw eekdnds deluge. If the app doesnt tell you there is a known issue or offer to book an engineer call Skybyonreport the issue. Calls on your Sky Talk line are free if that is working dial 150.
09 Oct 2023 03:53 PM
@Chrisee @Had engineers out twice, both times said they'd fixed it. Couple weeks later, does it again.
09 Oct 2023 04:30 PM
Posted by a Superuser, not a Sky employee. Find out more@LeeShroff Sounds like theydid not find the fault. If you post your hub's stats forum members msybe able to help.see Find your Sky Broadband router statistics
