Discussion topic: Broadband keep disconnecting
Message posted on 22 Sep 2025 12:27 PM
Message posted on 22 Sep 2025 12:36 PM
Re: Broadband keep disconnecting
@Arshad_486 wrote:
Recently I switch over to sky broadband and sky mobile. My broadband keep disconnecting at times and it's very frustrating especially when you are working from home.
@Arshad_486
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
