Discussion topic: Broadband issues
This message was authored by: Roxley
Broadband issues
Hi
We have being having issues connecting to broadband since yesterday
the routers has green lights but we not getting internet
reset the router 3 times and powered down but no success
sometimes internet comes on but goes off after 5 mins keeps flicking on and off
even on my phone keeps jumping from WiFi to 4 g
please advise or arrange an engineer visit
thank you
Re: Broadband issues
@Roxley
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
