Discussion topic: Broadband issues
This message was authored by: Terriblewifi91
Broadband issues
I have had issues with my service every day since its been installed. Can this be removed as I have had enough now! Thanks
Re: Broadband issues
@Terriblewifi91
Not sure what you mean by can it be removed ?
When it is down after midnight to around 6am then it could be overnight maintenance taking place as per this message at the top of the page:
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/m-p/5151847#...
If it still down later then the first thing to check is this link to see if there are any outages in your area, it doesn't always pick up issues straight away so it might be worth trying again later if this is the case:
If your ONT shows a red light then have a read of this:
If there isn't try running the line test here:
@Terriblewifi91
Do you mean you wish to cancel?
To cancel Sky Broadband and Sky Talk the below link explains how to switch to an alternative provider or the various methods on cancelling completely.
https://www.sky.com/help/articles/cancel-sky-broadband
If you try to cancel whilst still in a minimum term deal you might have to pay an early termination charge (Sky should notify you if you do and how much they’ll charge).
NOTE: One Touch Switching only applies to broadband and Talk and NOT a TV subscription.
Return packaging for any equipment Sky expect back will be sent out to you near the end of the 14 day notice period to the address the account was registered at. Remember to keep any proof of posting indefinitely.
