4
This discussion topic has been answered Discussion topic: Broadband issues
This message was authored by: SunilR
Broadband issues
There seems to be a problem with our WiFi as the signal keeps dropping and it says no internet despite having all green lights on the router and checking the system on Sky.com.
Re: Broadband issues
@SunilR
@SunilR
@SunilR Is your wireless wifi all good, ie all the bars and the ! exclamation mark on the device indicating NO Internet!
This message was authored by: PatrickMcN
My broadband this evening has been up and down and is currently offline
the lights on the router show different colours
location g69
@PatrickMcN
If this occurred before midnight the above post marked as the answer applies to you too.
When there are any broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
