Discussion topic: Broadband issues
This message was authored by: Dave864
Broadband issues
Broadband stopped working on Friday night, probably storm related. Since then, our connection has been largely non-existent. It has worked for 30-60 minute bursts each evening, but will then cut out. We didn't have any problems at all for the past 18 months or so, but this has now been consistent for 6 days. The orange 'voice' button keeps coming on. The online checker says that there are no issues in our area, but this can't be right.
Re: Broadband issues
@Dave864
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
