Discussion topic: Broadband issues
This message was authored by: PTS68
Broadband issues
Broadband keeps going off minimum twice a day
Re: Broadband issues
@PTS68
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
