Discussion topic: Broadband issues
This message was authored by: Sammulg85
Broadband issues
Broadband not working at home. Red light on hub. Sky states no issues/problems noted. Have followed the trouble shooting advice-no success. Is it just me or are other having problems? This has happened over the last 3 days intermittently. Thanks
Re: Broadband issues
@Sammulg85
Sky has over 6 million broadband subscribers so at any given time quite a few will have issues.
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
