Discussion topic: Broadband issues
This message was authored by: Neil208
Broadband issues
The broadband in our house is constantly dropping out . Really annoying I thought there may have been a local issue but the problem keeps on happening . I have run a test through your website which is showing everything as being ok but we keep having this issue. With the tv also being sky glass when this occurs we lose all of the tv also
Re: Broadband issues
@Neil208
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
