Discussion topic: Broadband issues
Message posted on 19 Jul 2025 06:16 PM
Broadband issues
Message posted on 19 Jul 2025 06:52 PM
Re: Broadband issues
@Aidancarter
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
