Discussion topic: Broadband issues
This message was authored by: Steve72x
Broadband issues
Broadband say it's connected and checks ran but still no internet any suggestions?
Re: Broadband issues
@Steve72x
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
