Discussion topic: Broadband issues
This message was authored by: Lucy171
Broadband issues
Just got my broadband today and it works good in my living room but any other room in my flat it just disconnects. Is a booster needed?
Re: Broadband issues
@Lucy171 make sure tge new Sky hub is in tge best position possible which is on a surface out in the open so its wifi signals is not being blocked unnecessarily. The issue with many blocks is the internal walls are often solid which does make wifi networking difficult so you msy need a booster which Sky will supply as part of their WiFi Max package see https://www.sky.com/help/articles/sky-wifi-max
