Discussion topic: Broadband issues - Scotland 29/04/25
Message posted on 29 Apr 2025 12:25 PM
Post created to collate broadband issues currently affecting Scotland.
Message posted on 29 Apr 2025 12:12 PM
Internet down
Message posted on 29 Apr 2025 12:15 PM
Wi Fi and Internet Outage
No WiFi connection despite test saying everything looks OK
Message posted on 29 Apr 2025 12:16 PM
Re: Wi Fi and Internet Outage
@Glengoyne
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 29 Apr 2025 12:19 PM
I have the same issue - glasgow based
Message posted on 29 Apr 2025 12:20 PM
Then post 2 applies to you too.
Message posted on 29 Apr 2025 12:21 PM
No internet
No internet test checker saying no issues have tried all steps and no light on router
Looks like sky is down across the whole of Glasgow then
Message posted on 29 Apr 2025 12:22 PM
I have the same issue, Isle of Skye based.
Re: No internet
@Joanne97
Re: Internet down
There appears to be various outages in Argyll and Bute
You would need to call sky
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
No connection- G61
Reset router and still no connection. Have run the diagnostic tools and nothing flagging. Can someone confirm if there is an issue in the area?
Message posted on 29 Apr 2025 12:23 PM
Re: No connection- G61
Message posted on 29 Apr 2025 12:24 PM
Issues in G15 blairdardie also.
