Discussion topic: Broadband issue
This message was authored by: BobbY48
Broadband issue
I can't connect to broadband I've followed all the instructions and there were 4 green lights on now there's 2 orange flashing light on and 2 green lights on
Re: Broadband issue
@BobbY48
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
