This discussion topic has been answered Discussion topic: Broadband issue
Message posted on 24 Feb 2026 07:10 PM
Checked plugs, connection secure, red light is still showing. Please can someone assist. Still haven't got a connection for broadband, wifi
Message posted on 24 Feb 2026 07:17 PM
@NIK47
@NIK47
