Discussion topic: Broadband issue
This message was authored by: KemalA
Broadband issue
My broadband isn't working, I've reseted my box numerous times and it's showing a amber light.
Re: Broadband issue
@KemalA
See further down about the lights on the hub.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This message was authored by: AshPhoenix
Re: Broadband issue
Mine is the same got finer installed because the old service was bad from day one this is worse it's been down for more than an hour when kids have PlayStations etc grrr
This message was authored by: Matt821
Re: Broadband issue
mine is down too what a day for it where abouts are you too
