Discussion topic: Broadband issue
Message posted on 31 Oct 2025 02:07 PM
Broadband issue
We keep losing burnet connection on a daily basis and it's very forstratimg now and we neee to talk to someone about it
Message posted on 31 Oct 2025 02:21 PM
Re: Broadband issue
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
