Discussion topic: Broadband issue
Message posted on 26 Jun 2025 12:59 AM
Broadband issue
My broadband stopped working I tried resetting but still not working
Message posted on 26 Jun 2025 06:09 AM
Re: Broadband issue
When this happens between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working by 7am and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
