Discussion topic: Broadband issue
This message was authored by: Katiebebeh
Broadband issue
The wifi isn't working, voice light is amber and i've checked the connection online and it says theres no issues
Re: Broadband issue
@Katiebebeh
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
