Discussion topic: Broadband isn’t working
Message posted on 12 Apr 2025 01:23 PM
The internet light on the router is blank, the voice light is orange - power and WiFi are green. I have no internet. Currently using the local area WiFi to be able to get help. Have turned off and on again and have tried the service checker which is saying it is fine which it clearly isn't. Sky tv says no internet, the smart tv isn't working due to no internet.
Message posted on 12 Apr 2025 01:24 PM
Re: Broadband isn’t working
@Sarah1908
This should determine if there's an identified fault affecting multiple households.
Message posted on 12 Apr 2025 01:25 PM
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
