Discussion topic: Broadband intermittent
Message posted on 02 Dec 2025 10:00 AM
We have had sky 300Mb Broadband for 3 months and we have a problem where the connection just drops on any device more than about 8 feet from the Broadband Hub. Teams calls and working from home is impossible. We have rebooted the device, changed channel, changed to the older slower more robust Wifi connectivity but with no luck. Is the Sky Hub really this poor at providing a signal. The device is in an open area, not near any other device / TV / power point.
The issue seems to affect any device
As I sit here I am doing 3 broadband speed tests on my device
First test 22Mb Download 39Mb Upload
Second test 19Mb Download 36Mb Upload
Third test 6Mb Download 42Mb Upload
I've worked in tech for years and can't figure out why my down speed is so terrible and up is ok. There are only two of us in the house and we haven't got lots of tech devices connected and running. Our connection is so intermittent it is becoming unusable.
On multiple occasions Sky have reported problems, but the system always says they are fixed. What do we do now?
Message posted on 02 Dec 2025 10:56 AM
Re: Broadband intermittent
@lexicax White or black sky hub, that is Sky Max or the Sky Broadband Hub used on the connection? Linked below the current ones?
Message posted on 02 Dec 2025 11:16 AM
Not sky max, the standard sky broadband hub
Message posted on 02 Dec 2025 11:23 AM - last edited: 02 Dec 2025 11:31 AM
@lexicax If you can then would be good to see what a wired Ethernet connection is like speed wise to the sky Broadband hub, wireless can just be so oopsy if you have something going on with that, do a thinkbroadband speed test with both wired all wireless off, then a wireless also! Your result's posted are kind off point to a wifi issue! 2nd link gives you the idea, on a FF500 feed currently!
https://www.thinkbroadband.com/speedtest
https://www.thinkbroadband.com/speedtest/1764674742212892855
Message posted on 02 Dec 2025 11:26 AM
Hi Jim,
Yeah, the results point to a wifi issue. With wired, no issues. What i am asking about is why is the range so short that 6-8 feet with clear line of sight almost loses wifi completely.
Message posted on 02 Dec 2025 11:36 AM
@lexicax If that is the case with the sky hub, can be a few things, the hub wireless wifi is going bad, you have interference on your band wifi, something else is jumping in with demand on the wireless, like a bad app on a mobile phone, it's the same rules, one wireless device at a time, takes one rogue wifi device to cause havoc on a network!
Message posted on 02 Dec 2025 11:43 AM
Yep, checked all those things. There is one device only attached when i am doing this. We have 30 metres between us and any other routers so no interference. It's just weird
