Discussion topic: Broadband installation delays
Message posted on 06 Aug 2025 12:24 PM
I opted for Sky broadband installation on June
Openreach has rescheduled installation 7 times
now rescheduled for end of August!!
what sort of service is that!!
Message posted on 06 Aug 2025 12:31 PM
Re: Broadband installation delays
@FrancoCap given Openreach install over 10k fibre lines eaxh day of which a small % hut snags if which your's sounds to be one it isnt bad service but simply bad luck. Delays can have many causes but blocked ducts and trees blocking overhead runs are quite common.
Message posted on 06 Aug 2025 12:40 PM - last edited: 06 Aug 2025 12:51 PM
As @Chrisee indicates, while any individual installation is 100% important to the household involved, it's 0.0015% of the Openreach FTTP target for that week.
Putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
