This discussion topic has been answered Discussion topic: Broadband hub issue
Message posted on
15 Mar 2026
09:06 AM
- last edited:
16 Mar 2026
10:42 AM
by
SpaceSparkie
unable to access router even after factory reset, any ideas please?
I have tried the following to no avail......
user admin
passowrd admin
user admin
password password
tried admin
passowrd default on router
Moderator Actions: Retitled to better reflect issue
Message posted on 15 Mar 2026 09:34 AM
@Zac1335 to fully reset the black upright Sky hubs press and hold in the reset pin until the power led flashes which takes up to 20 seconds. Once restarted the web interface log in will be user = admin and the password will match the password printed on the label. Release too easly and the hub just restarts without the settings resetting.
However it is very easy to misread the label as Sky use letters like I and O and umbers like 1 and 0 which cannot be confused.
Message posted on 15 Mar 2026 09:09 AM - last edited: 15 Mar 2026 09:10 AM
Re: Sky stream router login
There is no 'Sky stream router': Stream is a subscription television platform.
The current Sky router models are the Broadband Hub, Max Hub and Gigafast+ Hub.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 15 Mar 2026 09:14 AM
im trying to access the sky broadband, my apologies, so i have
the black router
Message posted on 15 Mar 2026 09:28 AM
any further advise please?
Message posted on 15 Mar 2026 09:31 AM
@Zac1335 Your post has been moved from the Stream board as noted by @TimmyBGood it is unrelated to a Sky Stream Puck.
