Discussion topic: Broadband go off
This message was authored by: traceystimpson
Broadband go off
My broadband and voice has dropped out again ..it does it every day..sometimes for hours..mins or all day .online test show everything is ok when it clearly is not
Re: Broadband go off
@traceystimpson
If you haven’t done it already use the below link to check to see if there are any problems or outages nearby https://www.sky.com/servicechecker
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for traceystimpson
Thank you for your advice..I've done everything suggested...including turn it off wait turn bk on...online checker says all is ok I'm connected..but I'm not..so il ring again to book engineer as the last one did not turn up...wishing I had just kept the old line for broadband and never gone to full fibre..
Thanks again.
