Discussion topic: Broadband dropping
Message posted on 17 Dec 2025 12:58 PM
Broadband dropping
My broadband keeps crashing!!!
Message posted on 17 Dec 2025 01:01 PM
Re: Broadband dropping
@Sgodley
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
