Discussion topic: Broadband dropping
This message was authored by: Lea33
Broadband dropping
The broadband is dropping in and out. Unable to watch now tv
Re: Broadband dropping
@Lea33
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
