Discussion topic: Broadband dropping out
Message posted on 24 Aug 2025 06:10 AM
Dropping out every few minutes
Message posted on 24 Aug 2025 06:30 AM
Re: Broadband dropping out
@Nitram47
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
