Discussion topic: Broadband dropping out
This message was authored by: FionaSpink
Broadband keeps dropping our and doing everything recommended to restart but only temporary fix
Re: Broadband dropping out
@FionaSpink
If it's still happening and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
